Quadbeam HID
2 Attachment(s)
Finally decided to swap my yellow fog light HIDs to 9005s on my rig. Now I've got Quad-beam HIDs. 10000K in the 9005 and 12000K H1 in the Projector. I'm running the ballast off my fog light wiring. Allows me to used both at the same time. I love it!!!!! SUPER BRIGHT AND BLUE!!!
why not do the quad beam mod? fog lights don't get the direct power that head lights do. they're on a "try your best" circuit (don't ask me the tech terms, i don't know them) so when the truck recognizes you losing power they cut the power to the fogs and can burn up the ballast fast
Well they seem to work perfect for now, they only run off 35watts. Anyways I managed to break a CV joint today, when I slid down a steep muddy hill and bottomed out on the drivers side. Now it always makes a super loud cracking noise at about 5-10mph, and I can feel it slowing me down while driving. Gonna cost me $120 with shipping to replace both (figured I might as well) with some Cardone's from RockAuto. Thanks for the info, but I've never heard of that happening. I did have to leave the 9005 halogen light bulbs plugged in (now they're just dangling down behind the headlights), because the fog switch won't work with the night time lights on unless the 9005's are plugged in. I thought that was strange...
If I remember correctly the Fogs are tied into the high beams so that they cut off when the high beams are turned on.... without a complete circuit (highbeams missing) you could be SOL
yea this defeats the purpose of high beams. the actual quad beam mod is so simple to do... just a wire, wire loop and a self tapping screw... and why pick the 10000K? the blue isn't near as bright as white and your are more likely to get pulled over with blue lights that stand out like that. plus i don't think you would pass inspection with no actual high beams. If I were you I'd just forget about the fog light switch that is nothing but headaches when you start messing with that, just hardwire the yellow fogs that all of your lights can stay on once you do the quad beam mod.
(Post 376377)
(Post 376377)
10K is for nothing other than the look Will. honestly for best distance with the light you'd want the yellow 3000 bulbs but those are dumb IMO unless you drive a ricer and then..... you drive a ricer, enough said. Benedict is right with the fact of you want the closest to day light. i have 6000 and those are too blue for me. i'm waiting for them to blow up or i come into money before i swap them out.
Hopefully the OP does what Benedict suggested for the sake of simplicity and safety. BS? we're just trying to help you avoid headaches down the road. but i guess you don't like us looking out for you |
Originally Posted by MTopper
(Post 376384)
Looks cool, but not the right application.
