Radio static every time light bar turned on
Old Jan 9, 2021 | 11:50 AM
Jimmybuild's Avatar
Jimmybuild is on a distinguished road
Default Radio static every time light bar turned on
1996 jimmy.....Recently installed two front fogs, two rear fogs and a light bar. All led. Since then if i turn on either the light bar or the rear fogs the radio gets alot of static. Since i drive this truck 3 hours a day it really sucks. Any ideas to help? Thanks
Old Jan 10, 2021 | 04:53 AM
Factory radio or aftermarket install?
Who did the wiring of the radio?
Who did the wiring of the lights?
Do you have the static on every radio station?
Do you have that static also on the AUX (i.e. phone connected)?
Do you have that static on CD or Radio internal other player?
I would start by searching a station where you have that static all the time, then unplug the lights one-by-one.
Simplest solution is drive it with the additional lights off.
Old Jan 10, 2021 | 12:47 PM
Jimmybuild's Avatar
Aftermarket radio i installed over a year ago. Have had no issues. Wired in front fogs 3 weeks ago and led headlamps. No issues. Wired in upper light bar and rear fogs and when turned on all stations go fuzzy. I have done all of my wiring as i am a tech by trade and have never had these issues before. All lights are individually switch and both the upper light bar and the rear fogs affect it.
Old Jan 14, 2021 | 06:12 AM
Is it just static random noise or does it have a rhythm to it?
If it has pulses are they rpm dependent or speed dependent? (Thinking ignition related vs. VSS related signals getting into the system.)
In my parking garage depending on the tuned radio station i have the VSS signal in the background on my Blazer.
Just some thoughts.
Old Jan 16, 2021 | 10:20 AM
Jimmybuild's Avatar
No pulse just heavy static. Have seen others putting filters on the led wiring for noise. May try that.
Old Jan 17, 2021 | 03:11 AM
Another thought...
...check on the antenna connection to the radio. If the shielding is interrrupted (plug half way out) it will pick up any static it encounters because the radio station signal ist no longer strong enough.
Still I'd go and unhook one by one of the aftermarket lights to find the single source.
Old Sep 21, 2021 | 11:01 AM
jimspahr@msn.com's Avatar
It sounds like the rear fogs and/or the light bar has a bad ground. Check the grounds and make sure the surface is clean and tight.
Old Sep 22, 2021 | 09:00 AM
GeorgeLG's Avatar
LED lights use electronic ballasts with high switching frequencies that can radiate radio frequency noise. One way they do this is by turning the input or output power wires into transmission antennas and the solutions are using ferrite core suppressors/filters, moving the wiring/ballast around, using a different brand of LED set up that has better emi suppression. As recommended earlier checking your power and grounds is always a good idea but you most likely have noise transmission problem. Is there a difference in brand between the quiet and noisy LED’s?
George
Chris Edwards
Jul 15, 2018 08:57 PM
bobholets
May 13, 2014 02:42 AM
thrash902
Mar 29, 2010 11:15 AM
Spectreblazer
Feb 12, 2010 08:20 PM
JRR_11
Jan 11, 2007 05:52 PM
