RE; Signals
Old May 4, 2011 | 08:30 AM
kennybopaloo's Avatar
kennybopaloo is on a distinguished road
Default RE; Signals
the right side signals flash normal and the bulbs are good.
the left side signals flash very fast and the bulbs are good.
what could be the problem ??
if it is the flasher, where is it.
02 chevy blazer 4.3
thanks................................... .......
Old May 4, 2011 | 08:35 AM
rriddle3's Avatar
*Moved to 'Lighting and Electrical'. The 'General Chat' section is not for asking technical questions.*
Old May 4, 2011 | 08:45 AM
DySfUnCtIoNaL's Avatar
DySfUnCtIoNaL is on a distinguished road
Very common problem on 2nd gen Blazers, mine use to do it also.
The flasher is located behind the glove box door, just push the sides and it will fall right out.
You can then turn on your turn signal and hear the clicking, thats your flasher.
Here's the way I fixed mine months ago.
98+ flasher/relay mod for the fast flash - S-10 Forum
Old May 5, 2011 | 09:51 AM
Default REl Signal
Fixed.
I checked the large bulb on the drivers side on the lower part of the reflector.''apparently it was slighty loose.
I snugged her up and the signals flashed normally.''
No need for a new flasher.
Thanks.
Old May 6, 2011 | 04:53 AM
Default RE; Signals
when i got into town the left signal was flashing fast again. i will check the end of the bulb to see if it is messed up or maybe the socket is not good.
i thought i solved the problem......................
BlaZeR FXB1581
Jul 2, 2007 07:51 AM
BlaZeR FXB1581
Jan 22, 2006 11:51 AM
BlaZeR FXB1581
Sep 2, 2005 07:41 PM
mendez918
Mar 3, 2005 11:42 PM
blazin97
Feb 22, 2005 01:49 AM
