Rear window defogger relay
1 Attachment(s)
Recently I pulled the relay looking for a blown fuse. When I went to put it back in I realized it can plug in two different ways as evidenced by the mark at the corner of the relay. Could someone compare the one in my picture to the one in your rig to see if the corner mark is pointing towards the engine or away from it? The picture is taken from the drivers side front fender.
Anybody?
Originally Posted by G0LFADD1CT
(Post 696168)
https://cimg3.ibsrv.net/gimg/blazerf...e560550144.jpgFront of the vehicle is to the left and the left fender is at the bottom. |
Thank you Christine. Mines in upside down.
These relays can be installed in any orientation that they fit without worry (i.e. there is no up side down, etc.). The contacts for the switched & switching sides are across corners which is what facilitates this functionality and polarity on the switching side does not matter. If it did, the pins on the relay would be designed to only fit into the socket one way.
The reason for the corner mark on that relay body is due to the fact that the relay itself has a normally closed and normally open contact & associated pins (5th pin would be the normally closed pin). In this case, the normally closed pin is not present. If the relay had the 5th pin, then it would only have one orientation that it could be installed. You can verify this by pulling the relay and taking a look at the bottom side. You'll notice another pin that is through the base of the relay, but does not have the spade portion for connection to the fuse/relay center terminals. |
That makes sense. I was thinking that if it had to go in one way only why didn't they make it impossible to get it reversed. Thx.
Originally Posted by swartlkk
(Post 696694)
