Rear window defogger relay
Old Sep 21, 2018 | 09:29 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
Default Rear window defogger relay
Recently I pulled the relay looking for a blown fuse. When I went to put it back in I realized it can plug in two different ways as evidenced by the mark at the corner of the relay. Could someone compare the one in my picture to the one in your rig to see if the corner mark is pointing towards the engine or away from it? The picture is taken from the drivers side front fender.
Old Oct 2, 2018 | 10:20 PM
G0LFADD1CT's Avatar
Anybody?
Old Oct 3, 2018 | 12:12 AM
Here is my engine compartment fuse/relay box in my 1999 LT 4dr/4wd
Front of the vehicle is to the left and the left fender is at the bottom.
Old Oct 3, 2018 | 12:49 AM
G0LFADD1CT's Avatar
Thank you Christine. Mines in upside down.
Old Oct 3, 2018 | 09:06 AM
These relays can be installed in any orientation that they fit without worry (i.e. there is no up side down, etc.). The contacts for the switched & switching sides are across corners which is what facilitates this functionality and polarity on the switching side does not matter. If it did, the pins on the relay would be designed to only fit into the socket one way.
The reason for the corner mark on that relay body is due to the fact that the relay itself has a normally closed and normally open contact & associated pins (5th pin would be the normally closed pin). In this case, the normally closed pin is not present. If the relay had the 5th pin, then it would only have one orientation that it could be installed. You can verify this by pulling the relay and taking a look at the bottom side. You'll notice another pin that is through the base of the relay, but does not have the spade portion for connection to the fuse/relay center terminals.
Old Oct 3, 2018 | 01:08 PM
G0LFADD1CT's Avatar
That makes sense. I was thinking that if it had to go in one way only why didn't they make it impossible to get it reversed. Thx.
Old Oct 3, 2018 | 04:43 PM
I suspected the orientation might not matter but your explanation clears it up. Thanks!
ZR2Driver
Mar 28, 2018 07:14 AM
hoebob69
Jan 22, 2017 05:56 PM
Jamaroon
Sep 20, 2015 01:20 PM
joetri63
Jun 10, 2013 06:43 AM
suckerpunch
Oct 25, 2009 02:32 PM
