Rear wiper motor inop
Old Nov 10, 2013 | 03:16 PM
dave comey's Avatar
dave comey is on a distinguished road
Default Rear wiper motor inop
I have a 1999 blazer and the rear wiper motor stopped working. I believe I have traced the problem down to a faulty ground.
When I disconnect the harness connector from the rear wiper motor and connect terminal C to ground I have 12 volts.
End gate & glass closed w/w switch to low ignition switch on B to ground I have 12 volts.
Connecting C to A zero volts.
When I reconnect everything and jump the ground wire from the logic box to ground the system functions as it should.
Does anybody know where the A black ground wire physically grounds itself? I am suspecting a problem there. I could also have a break some where in the harness.
Any help or suggestions would be much appreciated.
Old Nov 11, 2013 | 04:31 PM
dave comey's Avatar
I did some more poking around and found a ground in the left rear next to the disconnect/connector for the left rear light assembly. When I check for continuity between the black ground (A) and the hard ground at that location there was none.
I suspected the ground wire would be broken in the area where the tail gate opens and closes. I removed the rubber flex shield that connects the gate to the body and protects the wire bundle. The black wire was broken.
I think this is a likely cause for a lot of rear wiper problems I have read about on this forum. During testing I found if the ground is partial and insufficient the motor will not operate and the logic box will make a buzzing sound.
Old Nov 11, 2013 | 06:40 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Could be worse like my motor and killed itself, it would jitter in place and not move at all. I got lucky one day you pull-a-part and found a new remanned unit in a bravada for like $16. Worked great ever since.
ChrisNick78
Oct 24, 2012 08:05 PM
drlivingston
Jan 10, 2011 10:39 PM
Roudy4x4
Jan 7, 2009 11:05 PM
randallxl
Dec 22, 2008 04:02 PM
smokingf350
Aug 28, 2008 04:55 PM
