replaceing stock headlights with hids
Old Mar 3, 2013 | 07:04 PM
BCKDOOR SL4MMER's Avatar
BCKDOOR SL4MMER is on a distinguished road
Default replaceing stock headlights with hids
im just looking for anyone who can help me with some info for replacing my stock headlights with hids. thank you.
(blazer 97)
Old Mar 3, 2013 | 08:57 PM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
Fairly easy to do with a little bit of know how.
Fyi putting HIDs in to non-HID housings is illegal and could get you in trouble.
Take a look here My H4-(2) H.I.D. Install (w/ pics) - S-10 Forum
and do more searching. You have a single bulb headlight, so stock you have a 35/55watt halogen bulb, and you should look at bi-xenon HID bulbs as they will have the high beam being halogen the low will be HID xenon.
Don't skip on the relays and you may want to look into the big 3 upgrade also.
Old Mar 4, 2013 | 03:56 AM
Thogert's Avatar
You may or may not have one bulb for both. You should be able to tell if you have the composites or sealed beam setup. Don't worry about doing the big 3 just for hids, you don't need it because hids actually draw less power once warmed up. Just use a relay harness as suggested.
If you have the composite headlights, you will need a 9006 kit for the low beams and a 9005 kit for the high beams. If you have sealed beams you will need an H4 conversion housing, then you would need a bi-xenon H4 hid kit. (or you can do a hid projector retrofit and not blind everyone)
Old Mar 4, 2013 | 09:50 AM
my headlights right now are those big square ugly ones
Old Mar 4, 2013 | 12:07 PM
Thogert's Avatar
Like this?
Old Mar 4, 2013 | 02:43 PM
yeah but all one piece
Old Mar 5, 2013 | 12:51 AM
Thogert's Avatar
Like this one?
Old Mar 6, 2013 | 02:24 PM
KerbyG's Avatar
KerbyG is on a distinguished road
If you have those, get the clear euros, and a 9006 hid kit, and you'll be good. Dont put HIDs in factory fluted lights or you will throw light everywhere. Or do a Retro like mentioned above
Crestwood1001
Jun 19, 2009 12:02 AM
juan8w1
Nov 9, 2008 07:08 PM
juan8w1
ChevyRacing88
Feb 27, 2008 03:01 PM
