Replacing HVAC Controls
Old Dec 13, 2011 | 02:54 PM
drumminsoul's Avatar
drumminsoul is on a distinguished road
Default Replacing HVAC Controls
I need to replace my Hvac controls on my 2005 blazer 4x4 and I just want to know if there is anything I should know before doing this. It seems pretty straight forward but you never know about these things and I don't want to create more cost by screwing up. Is it just plug and play? I'm sure someone here has changed there's so please help. Thanks a lot
Old Dec 13, 2011 | 10:37 PM
Rottidog's Avatar
If you mean the dial/s in the dashboard just mark wires, maybe take pics so you can see the colors or the wires & where they go & make sure the replacement you got is the same as what it's replacing.
Are you sure it's not a vacuum leak in the hose leading to them? I know mine are sketchy at best & need to be replaced because when I have it on floor heat there is still some air blowing through the upper vents. That equals vacuum leak or bad actuator gate in the HVAC. More likely vacuum.
Old Dec 15, 2011 | 03:39 AM
David Hineline's Avatar
David Hineline is an unknown quantity at this point
If it does crazy things like blow up, blow down hot cool hot cool always one or the other, check the vacuum line going to the tank in the driver's fender first they fall off and controls go nuts.
Old Dec 15, 2011 | 06:46 AM
Why are you considering changing the HVAC controls? What is going on? Do you have manual or automatic HVAC controls? Manual has just red & blue around the temp dial; Automatic has numbers around the temp dial.
fireman32_14
Jan 21, 2013 11:18 AM
porkfriedrice
Dec 7, 2012 03:15 PM
Vahomboy
Dec 29, 2010 07:22 AM
sdm1234
Feb 7, 2008 06:16 AM
virgs91s10
Nov 14, 2007 01:01 PM
