Reseting hvac system
Old Nov 29, 2018 | 09:22 PM
ratpackdad's Avatar
ratpackdad is on a distinguished road
Default Reseting hvac system
Can you reset the hvac system and if so how would you go about doing that? 98 gmc jimmy slt
Old Nov 29, 2018 | 10:56 PM
What do you mean by "reset"? When the power is disconnected from the vehicle, e.g. a battery change, on the Computer Climate Control systems the blend door actuator will cycle back and forth when power is resorted.
Old Nov 30, 2018 | 09:12 AM
ratpackdad's Avatar
Thank you for replying again. Your answer to the rest is what I was asking about, heard it could solve problem.Battery or fuse or relay pull also. But didn't say were to have controls set. Also do you think it could be the control unit its self.
Old Nov 30, 2018 | 01:17 PM
LesMyer's Avatar
Use the following steps to perform the calibration update:
  1. Turn OFF the ignition.
  2. Remove the battery positive voltage circuit fuse of the HVAC Control Module.
IMPORTANT: The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds .
Wait 60 seconds .
  1. Install the fuse.
Old Nov 20, 2020 | 05:06 PM
SandyP's Avatar
SandyP is on a distinguished road
HI, BRAND new user here my climate control on 99 blazer is totally dead. totally. I read some threads - can you tell me where I find the battery positive voltage circuit fuse of the HVAC control module is?/
Thanks in advance,
SandyP
Also the only other thing I have done so far is check the fuses for the HVAC both in the inside and in the engine compartment. so any advice on where to start looking is much appreciated!
SevillianSTS
May 15, 2015 04:08 AM
kota04sxt
Dec 10, 2009 09:34 PM
cjpost
Dec 27, 2008 09:16 PM
ChoochCharlie
Dec 8, 2008 08:57 PM
gERgMan
May 22, 2008 12:30 PM
