rewire help
Old Aug 6, 2011 | 08:56 AM
rust bucket's Avatar
rust bucket is on a distinguished road
Default rewire help
hi all need some help did a rewire on my 83 K5 most everything is working except the running lights in the rear end. i used the EZ 21 circuit 18 fuse harness this is my first rewire and i cant seem to figure out what the problem is in the tail section. possibly wired the head light switch wrong any help or thoughts would be appreciated. hopefully somebody has some experience with this harness thanks in advance.
Old Aug 6, 2011 | 10:39 AM
pettyfog's Avatar
I dont know anything about K5. I dont know anything about modder wiring harnesses.
I do know that you seem to be asking only those who use the EZ 21 harness on 80 series K5's to help you out.
If it were ME.. I would be providing info on what 'running lights' are supposed to do as opposed to the tail light system. I infer that they arent coming on at all.
Lighting systems are, after all pretty elementary, but minus basic facts even those who have solved that sort of problems arent likely to understand what you want to know.
If you wait a couple days though I'm sure someone who's done the exact same project will come on here..
Old Aug 6, 2011 | 11:04 AM
Default rewire help
preciate the input i got the tail section running lights working but now have another issue when i turn on my turn signals they stay solid they dont flash prior to splicing a ground into the headlight switch power wire and running it back into the the headlight switch its self all my turn signals worked fine but i had no running lights any thoughts?
Old Aug 6, 2011 | 11:18 AM
pettyfog's Avatar
Yeah...
Now I'm motivated to become more diligent in my own use of punctuation. I do tend to get sloppy sometimes.
I'm worn out just translating. Try 'bullet point' format.
Old Aug 6, 2011 | 12:15 PM
any thoughts on what would make turn signals stay solid when turned on instead of flashing like they should.
98blazin
Aug 12, 2011 10:09 PM
rust bucket
Jul 10, 2011 08:23 PM
Chevymarine
Feb 22, 2011 12:35 AM
2005Jimmy
Dec 6, 2010 07:55 PM
m5james
Oct 27, 2009 12:14 PM
