Short in wiring?
Old Feb 26, 2011 | 03:40 PM
TriBlaKer's Avatar
TriBlaKer is on a distinguished road
Default Short in wiring?
Recently my brake lights decided to stop working checked bulbs dbl checked fuses, replaced brakelight switch and now when i turn on running lights or head lights the brake lights comeon also except for the center mounted one, so im wondering where in the world I could have this short at, any ideas?
Old Feb 28, 2011 | 03:09 PM
Frog's Avatar
Frog is on a distinguished road
You might need to adjust the switch.
Sure you got the right brake lights switch????
Also, might check the tab that actually pushes on the switch it self....it might not be making contact with the tab and opening (turning off the brake lights) the switch like it should.
Do you have an VOM (Volt Ohm Meter) or test light?
Old Feb 28, 2011 | 05:36 PM
TriBlaKer's Avatar
Yes I got the right one, i havent checked the tab but i will when the weather clears up again, (im doing all this work in my driveway while it's still winter) and yes I do.
Old Feb 28, 2011 | 07:04 PM
Debonair's Avatar
Debonair is on a distinguished road
Sounds similar to what happened to me, try checking the harness itself and see if anything is bad
Old Mar 1, 2011 | 01:37 PM
TriBlaKer's Avatar
the brake switch harness?
Old Mar 1, 2011 | 07:41 PM
BlazinClinton's Avatar
BlazinClinton is on a distinguished road
when u turn on the headlights, the brake lights SHOULD light up, just not as bright as when you hit the brakes.
Old Mar 3, 2011 | 04:44 PM
TriBlaKer's Avatar
Alright, well then..
Any ideas as to what might be goin on anyone?
Old Mar 3, 2011 | 05:20 PM
Debonair's Avatar
no i mean the harness in the back that leads up to the brakelight/tailights
Old Mar 4, 2011 | 12:21 PM
TriBlaKer's Avatar
ah well ill have to wait for this freezing rain to stop so i can check that out, not having a garage is a pain in my ace.
Old Apr 4, 2011 | 01:00 AM
TriBlaKer's Avatar
Bump they started working for a while and they just cut out again today. Where can I find the harness leading up to the lights?
