Someone help!!!
Old Feb 12, 2013 | 03:02 AM
smithn6425's Avatar
smithn6425 is on a distinguished road
Default Someone help!!!
I just bought a 2000 chevy Blazer 2dr 5 speed 4x4 yesterday it drove great the whole way home no issues at all! I pull in the drive way park it, about 20 min later a friend saw the truck came over and asked to hear it run... It has a loud exaust so I gladly offered to get behind the wheel and rev it a few times... But it cranked over 1 time if that and the electrical when completly dead the dash overhead light EVERYTHING! Now the first thing I think is damn I must have left the head lights on. So I run grab the jumper cables hook em up and it melts my cables and they start smoking! So I unattach them and the next thing I figure was I blew a relay fuse so I had a fuse kit and went ahead and changed every fuse just for the maintaintce and what not. I try and jump it again and this time it cranks 1 turn again and completly dies, I have almost ZERO mechanics training besides watching friends please help me before I mess something up. Im guessing its the alternator or the battery is no good but then again this is my first car and Im 18 I had to work and save for this car for a long time and now Im broke and the truck doesent run please help a kid out.
Old Feb 12, 2013 | 03:58 AM
Twip's Avatar
a few things,
do you have a battery tester and someone that knows how to use it?
if so, test the battery. it could be bad. if its alright, put a battery charger on it and slow charge it. (low amps)
after you charge the battery up a bit, try and start the truck. it should start. if not, it could be your starter. what noise does it make when the truck tries to start? does the starter seem to be turning really slow?
we need a little more info to help you out. once we get a few things out of the way, we can help you fix it without spending a bunch of unneeded money.
keep us posted on your results.
Old Feb 12, 2013 | 04:30 AM
mr.vls's Avatar
Check the Battery Cable routing to make sure that it is not grounding on anything. I almost lost my Jimmy due to the battery cable shorting out and starting a fire in the engine compartment. But before the fire everything would go dead and come back again. Apparently the cable would intermittently rub against the chasis and cause a total short of the battery.
Old Feb 12, 2013 | 12:02 PM
smithn6425's Avatar
Default ...
ok so if I hook the jumper cables up while the other car is not running it will charge the battery but not enough to start it. it will crank one time and go completely dead again so I thought it wasnt sucking enough power so when I start the other car as soon as I do so the cables start melting and smoking.
Old Feb 12, 2013 | 01:37 PM
smithn6425's Avatar
Old Feb 12, 2013 | 07:06 PM
Twip's Avatar
sounds like it might be going to ground as stated above. chase them and see if there are any bad spots where the insulation has been rubbed through.
LeftBehindGadgets
Jan 25, 2007 12:48 AM
S10Blazer
Sep 25, 2006 03:18 AM
LT1KICKER
May 16, 2006 01:57 PM
VORTEXV6
Oct 17, 2005 11:54 AM
TONY_ton
Aug 28, 2005 11:25 PM
