speedo not working running out of options
Old Apr 13, 2012 | 07:34 PM
michaelmoodyblazer's Avatar
michaelmoodyblazer is on a distinguished road
Default speedo not working running out of options
I have a 2000 chevy blazer 2wd the speedometer and odometer are not working ive replaced the cluster and the vss because i was told it would be either of those. Now that i have tried both options and its still not working im turning here so any info would be greatly appreciated
Old Apr 13, 2012 | 09:45 PM
thinking maybe it could be a wire coming from the vss to the computer
Old Apr 13, 2012 | 10:57 PM
Ductapeguy's Avatar
Ductapeguy is on a distinguished road
i had this problem on my GMC Sierra,i replaced the cluster and the vss i sent it into the shop because i was fedd up with it after about 3 months and a speeding ticket.. The Mechanic told me it was a Solenoid on the transmission. not sure how honest he was tho. Hope this helps.
Old Apr 14, 2012 | 01:07 AM
pettyfog's Avatar
does your cruise control work? If not, put ohmmeter on pins 29,30
Old Apr 14, 2012 | 06:47 AM
yes the cruise control does work everything works just like it should. besides the speedometer and the odometer.
ductapeguy how much did they charge you for that?
Old Apr 14, 2012 | 07:26 AM
pettyfog's Avatar
Originally Posted by michaelmoodyblazer
yes the cruise control does work* everything works just like it should. besides the speedometer and the odometer.
*Then the problem is not between the transmission and PCM.
Check PCM C4 {black conn} pin 4 drk grn through c203 pin E11 to cluster conn A4. Dark green all the way.
NOTE: If you have aftermarket radio check to see someone didnt screw with the drk grn wire in radio harness {no idea why it goes there} see the simple diagram
Attached Thumbnails speedo not working running out of options-conn_view_pcm_c4.jpg   speedo not working running out of options-ckt_inst_clstr_r.jpg   speedo not working running out of options-ckt_vss_prkbrk_inst_clstr_r.jpg
Old Apr 14, 2012 | 02:03 PM
Ductapeguy's Avatar
it was around 210 dollars. but i honestly think the canadian tire mechanic ripped me off.
Old Jul 24, 2012 | 08:52 PM
Thines's Avatar
Thines is on a distinguished road
Is your speedo working now?
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
S10BlazerFTW
Jun 16, 2013 03:35 PM
mjw1991
Feb 24, 2013 10:18 PM
mattkc
20
Jul 9, 2011 12:14 PM
s15kid
Feb 22, 2007 05:35 PM
