Super Bright LED's
Old Dec 10, 2009 | 12:49 AM
hubbmatt's Avatar
hubbmatt is an unknown quantity at this point
Default Super Bright LED's
I installed some super bright led's in my dash which I'm very happy with, except the fact that my dimmer wheel doesn't affect them at all! There might as well be a flashlight pointed at my face while I drive! Am I going to have to install a separate dimmer? Or are they "un-dimmable"?
Old Dec 10, 2009 | 07:56 AM
Sisk's Avatar
LEDs for the most part are un-dimmable. You need to get a special kind of LED that will work with a dimmer. I can't remember the name of them though, but I have seen them on ebay before.
Old Dec 12, 2009 | 01:02 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Not true at all, they are totally dimmable, you just have to change the resistance that your using.
the reason your dimmer doesnt dim is because lightbulbs dim higher on the scale, so essentially you just need a bigger(ohm wise) potentiometer to get them to dim efficiently!
EDIT: Keep in mind though, the more you add resistance the more heat your going to create.
This is why i mentioned creating a "lighting bus", you could use a simple l7805 and a Potentiameter, and be able to dim all your leds.
Old Dec 12, 2009 | 01:05 PM
Sisk's Avatar
Hmm...well now I feel stupid lol. My bad. I assumed they weren't dimmable since I had seen special ones made for dimming when I bought mine. Thanks for clearing that up though. Makes sense about the resistance.
Old Dec 14, 2009 | 12:39 AM
hubbmatt's Avatar
I'm not quite sure what a lightning bus is??? Is this just to disperse the heat? What value of pot should I look for, here are the specs for my bulbs: http://www.superbrightleds.com/cgi-b...2Fg5_specs.htm
project85
Feb 1, 2015 08:32 PM
Jasongr81
Headers, Intake, & Exhaust
Aug 1, 2013 01:23 PM
96jimmyslt4x4
Sep 21, 2011 09:14 AM
96jimmyslt4x4
May 29, 2011 03:55 PM
