-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Tach wire stalls Blazer (https://blazerforum.com/forum/lighting-electrical-52/tach-wire-stalls-blazer-74019/)
71K5CST Sep 25, 2012 01:35 AM
Ok so I've gotten my fuel hose and line issue all sorted out! :icon_banana: But now another (older) problem is still baffling me. A while back I put a Pertronix Electric Ignition into the Blazer (1971 w/350) and when the tach wire is hooked back up to the coil it kills the engine. Unhooked it runs just fine but the second that wire touches the coil it's lights out. I have no idea what could cause this and it's annoying since I know that having a factory tach in a first gen Blazer is semi-rare and mine is inop :icon_cry:
swartlkk Sep 25, 2012 01:42 AM
You are connecting the tach wire to the ground side of the coil right? Connecting it to the positive side will short out the circuit.
CLICK HERE for an article with a good diagram courtesy of HotRod.com.
71K5CST Sep 25, 2012 09:13 AM
Yes we hooked it back up per the instructions included with the ignition. When that didn't work we tried the positive side and it did the same thing.
abig84 Sep 25, 2012 06:25 PM
if its a hei ignition set up it will say "tach" where you plug it into. if you are plugging it into the correct place and its killing the engine it is probably grounding out somewhere. i used to run a kill switch like that when i was way younger. turned out to be a stupid way to do it as it ended up shorting out my ignition module one day when i forgot to flip the switch before starting the truck. so maybe trace the wires make sure its nor frayed or smashed somewhere and grounding out
71K5CST Sep 26, 2012 11:00 AM
I will give it a try. There's a lot of wires under that hood ha ha but it will be worth it to hopefully get it working again.
mark71j Mar 22, 2021 08:11 PM
How'd that turn out?
swartlkk Mar 23, 2021 06:20 AM
Considering you bumped a thread having it's most recent reply 8+ years ago, I'm going to go out on a limb and say your chances of getting an answer are slim... Please be aware of the age of the threads you are replying to when asking these simple questions and not adding anything to the thread in question. While it would be nice if the OP had given resolution, asking for said resolution years later is likely not to happen.
mark71j Mar 23, 2021 09:35 AM
I'm starting to see why there are so many one post and done new members on this site. Cheers
DonL Mar 23, 2021 03:01 PM
:confused:
71K5CST Mar 24, 2021 10:25 AM
Wow, I can't believe I never responded to this thread! I'm sorry for my poor etiquette! I tried one of the solutions above, it wound up being the tach wire that was frayed and grounding out. Once I covered that up, it worked great!
