Top break light thinks its a tail light?
Old Jun 29, 2022 | 03:03 PM
Le1's Avatar
Le1
Le1 is on a distinguished road
Default Top break light thinks its a tail light?
Hello there!
I have a 1999 Blazer LT with a very strange tail light issue.
Last week I noticed that if I turned on the lights, the top break light turned on and that both tail lights were off.
If I press the break pedal the top break light becomes sliiiightly more bright, but the bottom ones are dead.
When I remove the 20A fuse Park LP, from underneath the hood, the top break light turns off (and the tail lights remain off).
With this fuse removed the break lights work when I press the pedal, both the top and the bottom break lights turn on as intended.
All other lights, hazards, indicators, headlights etc work as they should....
Any ideas to what the issue may be?
Old Jun 30, 2022 | 11:45 AM
Weird stuff like that is almost always caused by bad grounds. check all the grounds for the lights (starting at the tail lights) and make sure they're all clean and tight.
Old Jul 1, 2022 | 01:38 AM
Le1's Avatar
Le1
Alright. I have checked the ground connection for the rear running lights (the one in the right rear corner) and it looks fine. I have been looking in Haynes but can not really make out where the other connections related to the lights are located. Anybody knows where they might be?
Old Jul 1, 2022 | 08:35 PM
GeorgeLG's Avatar
Here ya go. Let us know if you need help debugging the problem.
George
File Type: pdf
TheZR2ThatCould
Jul 21, 2018 08:14 AM
neemo6
Jan 15, 2013 11:10 AM
WMWilson87K5
Sep 21, 2012 01:14 AM
Blazin1
Jan 12, 2009 08:10 AM
mikeywaynebygod
Nov 14, 2006 10:03 AM
