No tail lights
Old Jan 11, 2013 | 10:41 AM
neemo6's Avatar
neemo6 is an unknown quantity at this point
Default No tail lights
Im having an issue right now with now dash or tail lights. Strange this is that they work fine when the truck is started w/ the remote start unil the brake pedal is tapped. Any ideas as to where to even begin to look?
Old Jan 11, 2013 | 10:54 AM
Smitty Smithsonite's Avatar
Under hood fuse box, for starters. Might just be a popped fuse ... but then you'll need to figure out why it popped. Have any aftermarket lighting out back? If so, that would be the first place to check.
Here's a tip to save your fuse supply .. and your sanity -- wire up a light, and stick the wires in place of the fuse. If the light lights up bright, like you stuck it to the battery, then there's a short in that circuit. Remove or unplug wires in that circuit until the light gets real dim or goes out altogether.
Old Jan 11, 2013 | 02:48 PM
spittybays
Guest
Posts: n/a
Unplug everything from your remotstarter module and a new fuse. See what happens.
Old Jan 15, 2013 | 11:10 AM
criadoman's Avatar
criadoman is on a distinguished road
Actually there is another item that can cause this. Apparently in our model of Blazer the circut for the taillights comes through the Hazard switch. There was a recall issued some years ago on this. I replaced the Hazard lamp switch and have had no problems since. Hope this helps. By the way, a tell on this is that the brake light works and tail lights dont.
step66
Oct 14, 2010 04:52 PM
cdp1250
Feb 6, 2010 01:11 PM
ff162bfd
Oct 26, 2009 11:23 AM
sidviscious
Oct 8, 2009 08:38 PM
98BlackBlazer
Aug 28, 2006 01:31 AM
