Turn off daytime running lights?
Old Mar 14, 2012 | 07:52 PM
jbw23's Avatar
jbw23 is on a distinguished road
Default Turn off daytime running lights?
Is there a way to turn off your day time running lights?
Old Mar 14, 2012 | 07:57 PM
Blazer_LT's Avatar
Blazer_LT is on a distinguished road
if you have a dome over ride you can push it four times every time that you turn on the blazer. i am not sure about the other options. if you have an under hood fuse box there is a pin that you bend over and it disables the drl circuit and take a whole 2 minutes. try using the search function for DRL disable
did some digging and found you this
Originally Posted by Porkfist
On a 97 blazer the fuse for the daytime running lights is in the fuse panel on the drivers side of the dash. You can only see it when you open the door. There is one fuse that only supplies the daytime running lights, pull it out, end of story. I don't recall the number.
I did this years ago because they annoyed the crap out of me, if I want my lights on I'll put them on.
Old Mar 15, 2012 | 11:40 AM
jbw23's Avatar
Alright thank you!
Old Mar 15, 2012 | 01:30 PM
NEW YORK BOY's Avatar
NEW YORK BOY is on a distinguished road
just push your emergency brake down a hair. and there you go!
Old Mar 15, 2012 | 06:50 PM
jbw23's Avatar
I took the fuse out but thanks
chester92
Nov 14, 2011 02:50 AM
antman94
Mar 7, 2011 08:12 PM
Benedict1337
Dec 10, 2010 08:30 AM
dave5point0
13
Nov 18, 2008 04:13 AM
RedBlaze
Sep 14, 2005 01:28 PM
