visor wires cut/ now lights and 4WD won't work
I cut the passenger side visor wires to disable the light after the cover broke. Now the dome lights, floor lights, engine bay light, and four wheel drive switches won't work. I tried splicing the wires back together and checked the fuses.
Always a good idea to tape them off, or small crimp caps. Be sure and double check all those fuses again as well. If you cut the wires at the same time then there is most likely a blown fuse somewhere.
99GmcEnvoy
Feb 14, 2013 08:36 PM
chevyracingfan23
Jul 11, 2012 01:11 AM
rogggg1020
Sep 24, 2008 06:53 AM
