? what is !and P stand for on blazer guages
Old Nov 12, 2010 | 11:43 AM
gar63's Avatar
gar63 is on a distinguished road
Default ? what is !and P stand for on blazer guages
have 04 blazer all brakes are working ,but on guages have an exclamation mark and p in red highlights ? what does this indicate, asking for help ,gar 63
Old Nov 12, 2010 | 01:04 PM
cbr995's Avatar
Parking brake
does it stay on?
I would check to see if your fluid is low, and if you're parking brake is disengaged all the way.
Old Nov 12, 2010 | 01:09 PM
gar63's Avatar
parking brake? is it a fuse or relay or is it external? e-brake isnt set or depressed.
Old Nov 12, 2010 | 01:20 PM
Lift up on the parking brake lever and see if the light goes out.
Old Nov 12, 2010 | 01:43 PM
mdehoogh's Avatar
Yes that's the light for the parking brake.
If it's still lit up even without the parking brake engaged, check the connection for the switch at the top of the brake lever assembly. If I remember right, the switch is made up of a contact bent towards the pedal, when you press the brake, the pedal touches the contact and completes the connection.
It could be that the contact is bent forward and the connection is still completed when the pedal is up
chris015
Feb 10, 2012 06:00 AM
fast eddy
Performance & Brainstorming
Aug 1, 2010 09:45 AM
Red Horse
Oct 14, 2009 12:48 PM
Crestwood1001
Jun 1, 2009 05:28 PM
blazingsadle
Feb 19, 2006 12:13 AM
