What's this?
Old Aug 17, 2013 | 03:19 PM
BlazN's Avatar
BlazN is on a distinguished road
Default What's this?
Found attached behind the dash around the far left vent, has the 7mm bolt similar to the ignition switch has a bunch on relays on it. Figured this could be where my problem is and as to why my gauges are messed up along with the odometer. Bad relay maybe? Cause it controls all the instrument cluster.
Old Aug 17, 2013 | 03:33 PM
Twip's Avatar
year, make, model of the car?
it is a relay hub of some sort, im just not too sure. could you possibly post a picture of where it came from and what it was connected to?
Old Aug 17, 2013 | 04:03 PM
BlazN's Avatar
[IMG]<a href="http://www.freeimagehosting.net/egx26"><img src="http://www.freeimagehosting.net/t/egx26.jpg"></a>[/IMG]
98 blazer 2WD and it just connect to a harness under the dash
