Why is iT ALL SO HOT
Old Aug 26, 2016 | 04:45 PM
itsjoshman's Avatar
itsjoshman is on a distinguished road
Question Why is iT ALL SO HOT
Got a 2000 Blazer here, and I will be just starting the truck up, or ill be going down the road at 50, or merging into a turn lane and slowing up and my parking break light and ABS light come on. But thats not all. My gas gauge and temp gauge will be all the way up at half way when the truck doesnt even have a key in it, and ill flick the high beams on and theyll drop to nothing, and slowly climb back up after a half a minute or so. But even worse, ill go to change the radio station to another preset, or turn my air up, and my buttons and ***** will be burning my fingertips up. I put a CD in the reader and as soon as my mom got in she could smell it burning up. Am I gonna have to trace the entire wiring system for the problem?
Old Aug 29, 2016 | 09:44 AM
rockp2's Avatar
Is it an aftermarket stereo system? I don't know what year they started putting CD players in. If it is aftermarket was it wired through the fuze block? If so, I'd try pulling the radio fuze and then doing some test driving. If it isn't wired through the fuse block, I'd try disconnecting the power to the stereo (and any other stereo components that are powered) to see if there is any difference.
Old Aug 29, 2016 | 06:00 PM
itsjoshman's Avatar
It is the stock radio, but this one did have some kind of alarm system installed by best buy, a blackcat I believe? does that make a difference?
Old Aug 30, 2016 | 10:51 AM
rockp2's Avatar
Where does the alarm system draw it's power from? Is there a fuse that can be pulled to see if it is the culprit? From what I have learned, many times electrical problems can be traced to after market items installed incorrectly.
Old Aug 30, 2016 | 02:56 PM
itsjoshman's Avatar
It goes to the inside fuse panel, but Im not sure what fuse it would be
Old Aug 30, 2016 | 04:16 PM
rockp2's Avatar
1. Pull in to your least favorite neighbors driveway.
2. Set off the alarm.
3. Pull fuses and replace one at a time (taking a 30 second break between each one), until the alarm stops.
Seriously though, you can do a continuity check to find the correct fuse. Just put your DVOM into continuity mode, probe the wire (pierce the coating) with one lead and use the other to touch the back of each fuse until you get a tone. If you look close at your fuses you'll see that both metal legs of mini fuses extend to the top of the fuse and are not covered by the plastic casing. Saves from having to actually pulling a fuse out to do any kind of check.
Old Aug 30, 2016 | 10:00 PM
itsjoshman's Avatar
I do hate to say, I have no remote for the system and I have no real idea of the system at all. I just bought it from someone who didn't even know it was installed. I can gather pictures tomorrow when I get a chance of the little box and all the ugly mess of wires
Old Aug 31, 2016 | 01:32 PM
richphotos's Avatar
If you have no remote for it, you can always trace all the wires where they are tapped and spliced and reconnect everything to how it should be factory.
Old Sep 1, 2016 | 03:34 PM
itsjoshman's Avatar
and how would I go about that? Taking out the dash?
danjdugan
May 14, 2011 02:45 PM
Mandrwj
Apr 10, 2011 07:32 PM
blazinloud
Jan 5, 2011 10:29 AM
bigdaddykane93
Jul 13, 2010 01:37 AM
ravenhurst
15
Apr 26, 2009 07:53 AM
