-   The Lounge (https://blazerforum.com/forum/lounge-5/)
-   -   Does not fit ZR2 (https://blazerforum.com/forum/lounge-5/does-not-fit-zr2-99123/)
OlympicWhiteZr2 Mar 17, 2019 05:57 PM
Does not fit ZR2
I'm getting a little frustrated with all the parts listings... nothing seems to fit ZR2s... no lift kits, no brush guards... I dont wanna give up my ZR2. It was a gift from my wife 8 years ago.
cleburne red Mar 17, 2019 08:08 PM
That sucks, man. It's already hard to find stuff for these trucks as it it, even less for the ZR2s.
Start getting that SAS worked out!
eshaw Mar 17, 2019 09:06 PM
Here's a body lift,
  • Mfg: Zone Offroad # C9201. If you want a suspension lift you really should think about doing a SAS because the cost will be pretty close to the same. When all is said and done you'd probably be happier with it. But that's if you're able to do a lot of the work yourself. Why won't a bush guard fit a ZR2? I'd ask the manufacturere or seller what the difference is.
go chevy Mar 18, 2019 09:04 AM
I am surprised that it is hard to find what you are looking for on a ZR2... Since they were built for more off road fun than a regular 4x4 Blazer I just thought upgrades would be plentiful... I was always told Rockauto.com had tons of stuff but I never have used them personally.
cleburne red Mar 18, 2019 10:03 AM
The problem I bet is the points on the frame that the suspension attaches too are different on the Zs, since they're a couple inches higher than a regular Blazer. Just about every lift kit is only for a regular Blazer, and won't fit the ZR2s.
Probably just a matter of how big the market is for each. Far more regular Blazers produced than the ZR2.
go chevy Mar 18, 2019 12:06 PM
That makes sense I guess... Those little trucks were made right from the factory to just get down and dirty I hear :) Hard to believe he can't find a simple brush guard though... Maybe suspension or body lifts, but a simple brush guard? That sucks lol...
cleburne red Mar 18, 2019 12:13 PM
Wonder what's different that the brush guards don't fit? Might be worth giving it a try, if you could get one cheap enough that it wouldn't be a big gamble
OlympicWhiteZr2 Mar 18, 2019 09:08 PM
it has to do with the mounting points and the OEM recovery hooks
DonL Mar 18, 2019 09:13 PM
I'm wondering how hard it would be to cut an angle iron to size. With a nice thick gauge, and good bolts, could just be a matter of a couple of grinder cuts, and a few holes. That's what I did with my, never came with any mounting brackets, just found some good 3/8 thick angle, drilled some holes to where it would match the tow hook holes, and voila!
I dont mind retrofitting tho, with a little elbow grease, anything can look like factory...
