i know it is not a blazer. 04 drango sevear overheat
Old Jun 13, 2013 | 11:17 PM
igs4dragon8's Avatar
igs4dragon8 is on a distinguished road
Default i know it is not a blazer. 04 drango sevear overheat
i have replaced my thermostat, tried to bead all the air from the bleeder plug. and it is still overheating. has the rear ac and heat.
still gets overheats with the guts of the tstat removed.(old)
i know it is not a blazer. but it is my moms, and i am stumped
Old Jun 14, 2013 | 12:50 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Have you checked the water pump to make sure it's moving water? Sometimes the water pumps fail and that can cause overheating. Have you checked the heater core for blockages? Have you flushed out the cooling system? Have you verified that the fan is working properly? Is the radiator blocked? Since you've already done the easy things you need to look at the overall cooling system and test every part of it.
Old Jun 14, 2013 | 01:24 AM
step66's Avatar
Yes,Toby hit all the obvious,which is what you should be looking for. My daughter has one of these(though I've never seen it except in pix) and there is a forum for these units as well! I'm sure its a simple solve issue!
Old Jun 14, 2013 | 05:15 AM
Rumblur's Avatar
Rumblur is on a distinguished road
04 Durango.... 4.7 engine? You're screwed. Those things are junk. There are SO many things that go wrong with that engine... actually all the .7's are the same way. I've seen them bend rods from being hot. Is the crankcase overfilled? They are bad to blow headgaskets as well. I'd get someone to pressure test it, I bet you either have a bad gasket or a cracked head.
matchews44
Jul 14, 2012 05:10 PM
BEAT MY JIMMY
Jul 21, 2010 01:13 PM
gotti3586
Oct 16, 2009 08:50 PM
blk97blazer
Feb 16, 2007 08:32 PM
il67bp
Aug 18, 2005 12:26 AM
