Slow turn signal ( Cavalier )
91 Cavalier. W/O Cruise. When I use the turn signal, sometimes it works really slow or sometimes not at all. Is this the turn signal lever arm or something else, thanks.
well i dont know much about the 91's but it could be, when it doesnt work does the blinker light stay on? if so try to replace the bulb, one website that deals with cavaliers and sunfires will help you
its called
http://www.j-body.org
good website, reigster and use the search (free reg)
its called
If you click on your signal light, then get on your back on the drivers floor and search for the thing thats clicking above the brake pedal, you will find 2 of them. Try switching them. One is signals, one is 4-ways... If they speed up again, then that flasher is bad.
The flashers are about $7 each, so you may just want to change it out.
