Z85
Old Dec 11, 2006 | 03:12 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default Z85
So I did a bit of research and found out that not all blazers are created equal..... some came with a Z85 suspension package..... Upon more research, I found that the Z85 is basically a compact Z71 without the skid plates. . . . . My blazer has it, who else has it?..... to find out look on your RPO code list in the glove box for code Z85.... I'd kinda like to know...lol
Old Dec 11, 2006 | 03:55 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: Z85
Here are the suspension packages that the blazers were offered (for anyone that's curious):
Z83: Smooth Ride Suspension Pkg. (Models w/108.3" WB)
Incls: HD Shocks.
Z85: HD Suspension Pkg. (4WD Models w/108.3" W.B .)
Incls: HD Rear Springs & HD F&R Shocks, P235/70R15 BSW Tires.
ZM6: Off-Road Suspension Pkg. (4WD Models w/108.3" WB)
(NA 2WD Models or 4WD Models w/117.9" WB) Incls: Special Bilstein Gas Shocks, Larger Torsion Bar, Jounce Bumpers, Stabilizer Bar, HD Springs & (5) P235/75R15 On-Off Road OWL Tires.
ZR2: Highrider Suspension Pkg. (4WD Wideside w/108.3" WB & SLS Sport Pkg.) (NA 2WD Models or 4WD Models w/117.9" WB & SLS Sport Pkg., Sportside or w/SL Pkg.)
Old Dec 11, 2006 | 04:04 PM
a_tack's Avatar
Default RE: Z85
thanks jigg... I was trying to find a description..... is it possible to have heavy duty and off road suspension??? because I have the rpo code for z85 in my glovebox...but under the truck I have the bilsten gas shocks, larger torsion bars than my buddy's blazer, hd springs, the bumpers and such...... i dunno...lol this truck confuses me..... because its the bigger wheel base.. but I definitely have different heavier duty suspension than my buddy's 2000 4 door 4x4...lol
Old Dec 11, 2006 | 04:14 PM
Jigg's Avatar
Default RE: Z85
I suppose it could've been special ordered, but i don't think i've ever seen a 4dr ZM6. I know my brother's 4dr blazer is a Z85 and his didn't come with bilsteins.
I'd check in your glovebox and see what it says.
How'd you measure the torsion bars to find that they're larger than your friend's blazer? If he's got the Z83, that might include softer springs and whatnot... i really have no idea.
Old Dec 11, 2006 | 08:07 PM
blazinloud's Avatar
Default RE: Z85
were the same options available in the GMC Jimmy?
Old Dec 11, 2006 | 08:23 PM
Jigg's Avatar
Default RE: Z85
Yes... the Jimmy was only available with the ZR2 option in 2004-2005 i think.
Old Dec 11, 2006 | 09:19 PM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
Default RE: Z85
that must be different for certain years then because I have the Z85 in my glovebox but i have 235/75/r15s, bilsteins....wonder if havingthe twoing package changes any of that?
Old Dec 11, 2006 | 10:25 PM
a_tack's Avatar
Default RE: Z85
yeah... i definitely have the off-road components but mine says z85....
Old Dec 12, 2006 | 03:09 PM
blazinloud's Avatar
Default RE: Z85
damn, im gonna go check mine, I've already gave my front end a pretty good beating.......any sort of preventative maintenance a guy can do up there isit basically fix it when it breaks.....
Old Feb 12, 2009 | 10:51 PM
kgkern01's Avatar
kgkern01 is an unknown quantity at this point
Default RE: Z85
Wow, bringing up an old thread here, but just like a_tack, I have a 2001 LT 4x4 4-door with Z85 code, but it also has the Bilsteins and HD suspension as well. As I checked further into my other RPO's, I found Z82 code which are "Trailer Provisions, Special Equipment, Heavy Duty", I wonder if this package included the same features as the ZM6 but called it a Z82 code as a "trailer package" rather than a "off-road" package for the 4-door LT models? What do you guys think?
