Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
4wd question
Old Sep 8, 2008 | 11:51 PM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
Default 4wd question
right now i have the torsion bar adjuster loosened all the than snugged.. i want to be lower.. what happens if i remove the torsion bar? am i stuck with only a three inch drop? my truck has 4" blocks in the rear and all that weight comes out to like a 5-6 inch drop for the rear.. i have stiff coil overs so i don't bottom out and it really doesn't ride bad.. corners very nice
Old Sep 9, 2008 | 06:04 AM
Default RE: 4wd question
Take out the torsion bars... That would drop the front end for sure, but you would be riding on the bump stops. The torsion bars are the spring in the suspension, you do not remove them without significant work.
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
1badblaze
Sep 29, 2008 05:50 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
