air bags
yes your can but how much money and work do you want to put init and youll loose your fourwheel drive, at least the way I would do it. I am currently bagging my 94 s10 2wd good place to go is s10forum.com and look around they also deal with blazer stuff. but why bag a 4wd its almost a waste. you need to get your hands on a 2wd and keep the 4x4 for a daily driver.
Bagging a 4wd, it is possible and can be done if your willing to part with all your 4x4 stuff and convert it to 2wd or you can get a rolling chassis 2wd and swap everything over if you want to keep everything outta the blaze you have! If you insist on building the 4x4 into a bagged frame dragger then the biggest suggestion is to build a custom frame anyway!! So it boils down to this, either sell the blaze you have and get a 2wd or go and buy a 2wd and build that and keep the 4x4 as an offroad toy!! Starting with a 2wd when putting on air suspension is the way to go its alot cheaper and quicker to do then modifing a 4x4!!
you can keep the 4wd but you cant drive with it aired out. check on s10forum.com and type in "Only awd bagged syclone". he lives just north of me and he has an awd syclone that is bagged and when aired up can still drive.
blazer_project
Mar 9, 2009 09:02 AM
