Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
dropin it
Old May 18, 2009 | 10:18 AM
spankyy's Avatar
spankyy is an unknown quantity at this point
Default dropin it
okay welll i want to do a 3-4 drop on my 4wd blazer an for now im leavin the stock tires on it if they fit they are 23575r15s will they still fit an dose anyone have any pics of a 4wd lowered jw what it will look like
thanks Josh
Old May 18, 2009 | 02:57 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
That should answer your question. I dropped mine 3/3 and the tires fit fine, you can see in the back i have more room to go.
Old May 18, 2009 | 03:36 PM
okvortec's Avatar
Wow, very clean blazer.
Old May 18, 2009 | 08:59 PM
blazen99's Avatar
blazen99 is on a distinguished road
lol looks about where mines sits with out a drop in it. haha i need new suspension.
Old May 18, 2009 | 09:51 PM
spankyy's Avatar
the funny thing is that blazer is the same color an everything as mine lol an that looks sweet
what kinda lowering kit did u get an did u just loosen the tbs up or did u use keys
Old May 18, 2009 | 11:15 PM
i took out the bolts pretty much all the way and got blocks from beltech.
Old Jul 12, 2009 | 04:03 PM
spankyy's Avatar
i found a set of lowering blocks an autozone an there like 30 bucks would thay work an then just lossen the tbars upp
Old Jul 12, 2009 | 04:08 PM
oktain's Avatar
The blocks are just for the rear axle, mounts the axle closer to the frame dropping the truck closer to the ground. *Axle goes up, truck goes down* lol.
Old Jul 12, 2009 | 06:59 PM
spankyy's Avatar
will i have to cut my rear bump stops at all an do i have to have shocks
Old Jul 12, 2009 | 08:44 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
dependinng on how low you go in the rear you may have to cut your bumpstops and shocks arent required, but are recomended.
