Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
How low can I go?
Old Dec 7, 2008 | 12:01 AM
Tahoe_Jr's Avatar
Tahoe_Jr is an unknown quantity at this point
Default How low can I go?
I was thinking about lowering my 2WD 4DR s10 blazer. But I don't know how low I can take it before I would have to C notch my frame. I want the most amount of drop I can get but don't want to have to make drastic changes just yet.
Old Dec 8, 2008 | 09:30 PM
thegr81's Avatar
Default RE: How low can I go?
You can go with a 4inch tapered drop block in the rear and keep all your leafs for ride quality and then do a 2inch drop spindle in the front with either a lowering lower control arm so you don't have to go with a drop spring or get drop springs and shocks for the front with the spindle and you will be looking at a nice stance also depends on what size wheels your running as well!! Look at my pics I have a few of mine lowered on 18's with probably I think 1 inch of gap in the front and 2inches in the back before I went lower!! If you need some place to find a lowering kit there is streetbeatcustoms.com they are the cheapest I have found for drop kits!! Hope this helps!! Also the 4inch tapered drop block in the rear is the lowest without doing a c-notch!!
Old Dec 8, 2008 | 10:13 PM
Tahoe_Jr's Avatar
Thanks that helps alot.I was hoping that I could go 4" drop in the back without a c-notch. Thanks
Old Dec 8, 2008 | 10:30 PM
thegr81's Avatar
No problem I am currently running a 4inch tapered drop block to maintain pinion angle for the rear diff. but soon I am going to have to do a 2inch lift spacer to my trans. mount when I bag the rear. The front of mine is bagged laying crossmember but I am soon going to bag the rear which with money being so tight all year is finally going to happen soon I hope LOL!!
Old Dec 12, 2008 | 05:43 PM
Tahoe_Jr's Avatar
Cool. Your truck is clean. What size rims are on the front? They tuck up in to the fenders nice.
Old Dec 22, 2008 | 02:27 PM
thegr81's Avatar
Thanks my rim and tire combo is 215/35r18 and they tuck without rubbing.
Old Jan 4, 2009 | 03:09 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
hey i got a set of 20's that would work great on that blazer pm me if ya interested
jdiaz
Sep 26, 2023 11:29 PM
Streetracer94
Oct 29, 2018 09:33 AM
LioNiNoiL
Aug 4, 2011 02:47 AM
steve0o09
Lowering Tech
Sep 8, 2008 11:10 PM
bigbill23
Suspension Tech
May 15, 2007 10:05 PM
