Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
Lowered 4x4 blazer?
Old Apr 28, 2015 | 08:35 PM
1quickblazer's Avatar
1quickblazer is on a distinguished road
Default Lowered 4x4 blazer?
Hey I'm new on here, I live in Pennsylvania and really ever use the 4wd, I'm goin to be lowering my 97 blazer 4wd 4 door in the next few weeks, I got 3" blocks for the rear, I read and seen you just let the torsion keys out and it lowers the front, Is this true? Any pics of lowered 4wd blazers and help would be greatly appreciated...thanks
Old Apr 29, 2015 | 06:12 AM
You might want to seriously reconsider this idea. Unless of course, you don't mind needlessly throwing money at it constantly. If you adjust the torsion bars out of spec, you're asking for trouble, and you'll get it. Most of the steering linkage and suspension components will wear out prematurely, and in some cases, fail without warning causing a total loss of control. This is not a good candidate for lowering. If you need a lower vehicle for the ease of entering/exiting, look for a Blazer Extreme.
Old Apr 29, 2015 | 07:16 AM
Ok, I was just curious on how it would work, I've seen other threads we're guys have done it
Old Apr 29, 2015 | 12:37 PM
4WD vehicles are not designed with lowering in mind, (counter productive). A body lift is far more common, but it too presents problems of its own. As long as you keep front chassis ride height within spec, you'll be fine. However, with the mods necessary to lower, that will be a serious challenge. If you need the procedure and specs for measuring & adjusting, just ask.
Old Apr 29, 2015 | 03:15 PM
I deft will ask in the coming weeks when I go to start it, thanks for the input
Old May 2, 2015 | 10:00 PM
rollinlow96s10's Avatar
rollinlow96s10 is on a distinguished road
i hate to argue with captain but i had my 00 4 dr 4x4 lowered 3 inches all the way around and didn't have much problem at all other than normal wear and tear on it
Old May 2, 2015 | 10:59 PM
From post #4:
"As long as you keep front chassis ride height within spec, you'll be fine. However, with the mods necessary to lower, that will be a serious challenge."
That's not saying it's not possible, it CAN be done.
Old May 3, 2015 | 04:49 AM
How did you lower yours?
BLAZER97LS
Lowering Tech
Nov 26, 2012 06:40 AM
blazer206
Lowering Tech
38
Jan 15, 2011 11:19 AM
blazer206
Lowering Tech
Feb 22, 2010 12:32 PM
gstxtt
Lowering Tech
Oct 14, 2009 06:00 PM
blazer206
Lowering Tech
Feb 13, 2009 05:49 AM
