need help!
so i spent the day today tearin apart my blazers front springs or should i say trying i had the tire and all castle bolts of of everything(upper n lower arms, and tie rod) i got the top loose but as you all now you have to ge tthe bottom loose how do you go about doin that cuz i had a hammer and friends lol and it would not come out am i missin somethin or should i get the good ole [b and soak it???
The tapered fit of the ball joints can be a pain to loosen. I will typically hit the steering upright on the flat that is to the inside of the upright. If that doesn't work, then you may need a pickle fork (U shaped wedge type tool for separating ball joints). Problem with pickle forks is that the use of them can damage the ball joint. Not too much of a problem if that is what you are replacing, but if you are not planning on replacing them...
maximashift
Nov 17, 2009 09:36 AM
blazin4eva
Jan 27, 2005 02:02 PM
