2000 Jimmy 4wd with Blazer wheels
Old Oct 8, 2013 | 07:57 PM
gmcgrlk's Avatar
gmcgrlk is on a distinguished road
Default 2000 Jimmy 4wd with Blazer wheels
Hi Guys and Gals,
Just wanted to say hello and thanks for all the knowledge gained to help me fix my Jimmy. I just got done removing and replacing my auto tansmission. Once out, I took it to a tranny shop and had new sun gear installed. After installing, I would turn the key and the starter would engage right away. I was not turning the key to start. I was getting power to small solenoid wire by starter. After checking over, under, around, I found a reference to remove the BU/LP fuse above driver wheel well. If removing it solved the problem, replace the neutral safety switch. I replaced the neutral safety switch and it has started properly since.
Regards,
David
Old Oct 8, 2013 | 11:23 PM
Thogert's Avatar
Welcome to the forum.
Old Oct 10, 2013 | 10:29 AM
rexmburns's Avatar
Super Moderator
Welcome from VA!!
Old Oct 10, 2013 | 09:17 PM
gmcgrlk's Avatar
Thanks for the welcoming from Ohio. Anybody know when I will be able to view pictures, post some answers and ask questions? I almost have my Jimmy to where I can trust it for 10-20 miles without having to call AAA. I have 3 tows in my membership and used up 1 for venturing more than 20 miles. It seems 20 miles is my Jimmy's limit for now.
David
Old Oct 10, 2013 | 10:14 PM
Thogert's Avatar
You should be able to post a new thread in all but the classifieds section. Find the section you need on the main page, then there will be a button at the top and bottom of the page that says New Thread. Of course it is always appreciated when you do at least a preliminary search before starting a new thread.
Old Oct 10, 2013 | 10:47 PM
gmcgrlk's Avatar
Hi Thogert,
I just tried to answer to a guy having 4wd front dif problem since I just got through replacing shift fork area internals, acctuator cable and housing. I was told I don't have permission to post.
Regards,
David
Old Oct 10, 2013 | 11:45 PM
Thogert's Avatar
Ahh ok, sometimes there is an issue like this. rriddle3 should be able to help you out as he is an admin here. Send him a PM and ask him to help you out.
Old Oct 11, 2013 | 06:28 AM
rriddle3's Avatar
gmcgrlk,
The problem should be fixed now. Double check your email address to be sure it's listed correctly.
Old Oct 11, 2013 | 10:36 AM
gmcgrlk's Avatar
Hi RRiddler3,
Thank you! I did check my email and it is correct. I will try and post something later when time permits.
Regards,
David
Old Oct 12, 2013 | 10:42 PM
95BlazenLT's Avatar
95BlazenLT is on a distinguished road
Welcome from Michigan...
