2001 Blazer trans fluid way too full
Old Jul 16, 2012 | 10:29 AM
edrock589's Avatar
edrock589 is on a distinguished road
Default 2001 Blazer trans fluid way too full
Went to check my trans fluid after driving 30 miles. Found it about 2-3 quarts too high on dipstick. I have not serviced trans in over 2 years. I do not have any shifting issues. A Tech at Chevy told me the seal in between the transfer case and tranny may be allowing fluid to pass thru. Any suggestions what to do next?
Old Jul 16, 2012 | 12:02 PM
chris015's Avatar
Pop loose a cooler line and attach a hose. then get a friend and drain some fluid (start truck and let it run for 10 seconds at a time,while checking). Once its down to the full mark attach cooler line,drive it for a few minutes and check level.
For the tcase remove the fill nut,fluid should be at the bottom of the hole. if its super empty or LOTS of fluid gushes out when you remove it,sounds like the seals gone. If its low,top it off and check the fluid level after driving it for a while.
tttron
Dec 11, 2010 08:38 PM
RIFLEMAN 308
Jul 31, 2010 03:42 PM
CBlazer99
Jan 13, 2010 03:12 PM
m.sterner
Nov 29, 2009 10:34 PM
luthers97blazer
Nov 10, 2008 01:27 PM
