Chevy blazer
Old Jan 6, 2025 | 05:08 PM
kelly41042's Avatar
kelly41042 is on a distinguished road
Default Chevy blazer
I have a 2003 Chevy blazer it will work in 2 wheel drive but not 4
Old Jan 6, 2025 | 06:39 PM
Welcome to the forum. This is the place to figure out what is going on.
Before members can help, we'll also need to know if you have the 3-button or 4-button type transfer case. The 4-button one also has a "Auto 4wd" button in addition to the 2hi, 4hi, and 4lo buttons.
Common issues with the 4wd system include bad transfer case control modules (TCCM), bad connections to the TCCM, and no vacuum supply to the front axle actuator. There are other other causes, but these are a good start.
We will also need to know any other symptoms, e.g., Do the buttons for the 4wd activation blink when you request a change in the drive setting? Do you hear repeated clicking from under the passenger side kick panel (where the TCCM is located)? Does your HVAC system work correctly to direct air to the desired ducts? The HVAC system also uses engine vacuum so if that system is not working correctly, then it will also affect the front axle engagement.
ReddBlazer
Aug 20, 2022 03:01 PM
drego sumecki
Mar 14, 2014 10:33 PM
kehoemh
Jul 22, 2010 02:57 PM
noom14921992
Apr 22, 2008 08:41 PM
Hanr3
Jan 17, 2007 05:32 AM
