exhaust smells of gas rough idle
Old Nov 6, 2008 | 02:38 PM
juan8w1's Avatar
juan8w1 is an unknown quantity at this point
Default exhaust smells of gas rough idle
ok guys here we go first i started the truck and the motor runs t o smooth to be any t hing serious so i start thinking were getting alot of gas from somewhere i started reading here and you guysknow yourtrucks.. i pulled mycover off mine and i found a puddle on the driver side up front and a simular puddle up front on the passenger side i am posting image so you can see what i saw.
i am assuming i have bad lines do to the location and the way its all looking right now if my regulator was bad i think my passenger side would be completely clean and if the leak on t he driver side were more serious it would be clean also . the first quest ion is how does one go about removing the lines without damaging the unit ???????
thanks for being here and for making this info available have a great day
[IMG]local://upfiles/12671/8CDA0DA756FC495984FF7852CB41C102.jpg[/IMG]
[IMG]local://upfiles/12671/0668154662924EBE86129024E8281CEA.jpg[/IMG]
[IMG]local://upfiles/12671/B28EC2FC6894407DB8E258542FC83A00.jpg[/IMG]
[IMG]local://upfiles/12671/318DDA0A7142495B854B750A4E6A4B47.jpg[/IMG]
[IMG]local://upfiles/12671/844B9298CFD94EC4BCF1C9F35C00F079.jpg[/IMG]
Old Nov 6, 2008 | 02:46 PM
Default RE: exhaust smells of gas rough idle
There is a clip that holds the lines in place.
It definitely looks like your lines are leaking. On the passenger side, I'm not sure if your FPR is leaking as well or if that is just carry over from the other side (fuel drip that would cling and run along the underside of the spider itself). While you were in there though, I would replace the FPR with one of the new style units. Lindertech.com sells a kit.
Old Nov 6, 2008 | 02:52 PM
juan8w1's Avatar
i guess i was asking the wrong quest ion , how do you remove them from the cpi/spyder do they just pull out or are they pluged in some special way will i need any special tools to remove them i saw the clips that hold the lines into the intake thats easy but removing them from the cpi itself ?
Old Nov 6, 2008 | 04:27 PM
Same deal. There is a metal clip which must be removed before the lines can be pulled out of the injector body.
Old Nov 8, 2008 | 04:57 PM
juan8w1's Avatar
thanks for the advice you were correct and they came right out , i went and got the spyder and connected it but having trouble getting the feul lines reconnected with the orings on the lines they hang out to far to get the metal clip back on without they fit perfect could my orings be to big they are the exact same size as the ones that cam off it or do the lines need to be pressed on some how to get the clip back on ???? was looking forward to riding today dark may catch me before i figure this out please advise ?????? thanks guys your great
corhey88
Jan 21, 2010 06:28 PM
corvetteman
18
Jan 20, 2010 04:37 PM
pipslittlemomma
Feb 28, 2009 10:10 PM
ludejim
Nov 26, 2008 06:11 AM
BradensCreed
Nov 3, 2008 08:36 PM
