2000 blazer w/ "service 4wd" light on?
Old May 29, 2011 | 04:10 PM
mud_yeti87's Avatar
mud_yeti87 is on a distinguished road
Default 2000 blazer w/ "service 4wd" light on?
i have a stock 2000 blazer LT with the push button 4wd and the service 4wd MIL is on. It won't shift out of 2HI either. possible issues?
thanks in advance
Old Jun 8, 2011 | 12:16 PM
Volff's Avatar
Volff is on a distinguished road
Hey Bud,
I have a stock 2000 LS with the push button 4wd, I have the same issue, what i've been doing to get mine in and out of 2Hi and 4wd is theres a connection located under the hood near the hood light, I've been disconnecting that to get in and out of gear. What im going to do is take to a garage and have them dismount the front shaft and check the transfer motor, I replaced the motor when i purchased mine and it seemed to help but, still have the occuring issue
Old Jun 9, 2011 | 05:05 PM
mud_yeti87's Avatar
i've decided to do something that a buddy told me about. you go to a scrap yard or swap meet or wherever you'd normally get 2nd hand parts, locate an NP231 floor shift T-case, get the shifter cable, shift lever and bracket, and centre console out of a pre-'97 blazer/jimmy/s-10/sonoma that had a flor shift and swap that in. and to completly get away from vacuum lines, you swap the extension housing of the front diff with one from an AWD safari/astro van. i got all the parts i needed from a local scrap yard for about $60
BLAZE86DUBZ
May 11, 2014 03:02 PM
Geir
Oct 9, 2011 08:51 PM
slowtalker
Feb 17, 2010 08:52 PM
2001 ZR2
Jan 16, 2010 12:39 PM
99blzr
Dec 30, 2009 12:18 PM
