3 in body lift?
body lifts aren't expensive at all...usually around like $200. this place has a 2" but will give u something to start with
http://www.roughcountry.com/chevy_bodylifts.htm
I'm pretty sure they don't make a 3" for second gen blazers. I have seen people adapt first gen BL to work with second gen trucks through. It probably won't be an out of the box install. As for difficulty it depends if you have all the right toold to remove the body mounts and lift the body. I beleive you will also have to cut the fan shroud or install an e-fan.
ORIGINAL: tommyd
only 2"
