4 wheel drive 1985 questions
Old Nov 20, 2008 | 02:00 AM
wyk's Avatar
wyk
wyk is an unknown quantity at this point
Default 4 wheel drive 1985 questions
OK, I have an 85 blazer. Love it. But I got a few questions. I assume I need to be in Neutral to put it into 4 wheel drive etc. Also, is the selector lever mechanical, or electric? What's the max speed limits for 4 hi and low?
I have no RPO in the glove box. Could it be somewhere else? I was wondering what axel ratios these 4X4 autos came with in 1985. Otherwise, I love it!
Oh, one more thing, there is a hugely annoying squeaky rattle coming somewhere from the back. I can't pin point it, but the jack is out, and there doesn't seem to be anything loose. Is this common, or do I have to hunt down the source with a friend?
Obliged,
Wes
Old Nov 21, 2008 | 08:47 PM
wyk's Avatar
wyk
Default RE: 4 wheel drive 1985 questions
OK, no answers?
Old Nov 22, 2008 | 11:21 AM
vin791's Avatar
vin791 is an unknown quantity at this point
give it some time man.
4x4 is vaccum actuated
that's about all i know with what you asked except maybe the axle ratios are like 3.43 or 3.42 or somewhere in there
Old Nov 22, 2008 | 11:35 AM
blazinjeeps's Avatar
blazinjeeps is an unknown quantity at this point
Your back window is probably loose...just use electrical tape on the metal inserts. Just don't use too much or the window will not close.
Old Nov 22, 2008 | 12:34 PM
mysons95's Avatar
mysons95 is an unknown quantity at this point
Nice looking truck. I like that classic chevy color combo.
Old Nov 23, 2008 | 12:25 AM
wyk's Avatar
wyk
That's exactly what it was. Yer a badass, too.
OK part two: Will a torsion bar tweak give me 1" more without too many problems? I was thinking of going 2" in back and 1" in front(backs are sagging some).
Wes
Old Nov 23, 2008 | 12:43 AM
Blazin_Jason's Avatar
Park or neutral to go into 4wd and it's mechanical. I don't know for sure but I wouldn't go more than 80/90kms/hr in 4 hi, and crawling in 4 low. My 85 had 4.11's, but take your VIN to a GM dealer and have them run it for more info. Yes it's probably the rear hatch glass rattling. Also how is your rear spare carrier mounted?
edit: Ya you can go 1-1.5", I wouldn't go more than 2". Also would need to get an alignment done afterwards.
Old Nov 23, 2008 | 01:11 AM
wyk's Avatar
wyk
Yeah, it's da glass. I was thinking if I lofted it 2" or so, I could maybe fit some 31's in there.
My local Gm dealers can't go further back than 1991 on the VIN. Know anyone else I can maybe call and ask?
Obliged,
Wes
ORIGINAL: Blazin_Jason
Old Nov 23, 2008 | 02:41 PM
vin791's Avatar
a 91 would have the same coding i think. otherwise check out lmctruck.com and go to the catalog for s10 blazers
Old Dec 21, 2008 | 10:00 PM
Johns1987Blazer's Avatar
Johns1987Blazer is an unknown quantity at this point
4wd high I have been highway speed (55mph) no problems. 4wd low I think 20 mph is max. Shifter is cable actuated along with vacuum operation. Neutral is what gear you should have to shift it into 4wd. I have shifted mine into 4wd after shifting into neutral and still rolling (5mph or so) and it seems to be a LOT easier to shift into 4wd gears, especially 4 low.
