4x4 won't work?
Old May 23, 2020 | 09:25 PM
Boostedreed's Avatar
Boostedreed is on a distinguished road
Default 4x4 won't work?
I've replaced the actuator an cable. The vacuum seems to be pulling the cable but still no 4x4. I'm replacing a vacuum hose right now but still why isn't it working
Old May 23, 2020 | 11:31 PM
Is it that the front axle is not being engaged? Could it be that the transfer case is not engaged?
Old May 24, 2020 | 10:15 AM
The transfer case seems to engage tha front since shaft does
Old May 24, 2020 | 11:13 AM
If the cable to the front axle is being pulled by the vacuum, then perhaps the issue is that the gear that is engaged could be stripped.
I think you should be able to confirm if the front axle is engaged or not by lifting the front tires off the ground and checking if rotating one wheel causes the other rotate the othet direction.
Old May 24, 2020 | 11:38 AM
Yea I've tried that nothing happens
Old May 24, 2020 | 11:39 AM
What's that mean?
Old May 24, 2020 | 01:19 PM
The gear that can get stripped is #10 in the diagram below. I've seen it go by several names. One is Front Axle Disconnect Gear.
(https://nemigaparts.com/cat_spares/e...t/06/tt06-089/)
Old May 24, 2020 | 08:38 PM
I got it working actually n it works good! It was one of the vacuum hoses I replaced. It had a cut in it
Old May 24, 2020 | 11:07 PM
Yeah! Aren't those easy fixes the best!
Old May 25, 2020 | 03:01 PM
Yea I changed the actuator an cable n then a line I'm glad I was being dumb pulling on things I probably would of went through changing the transfer case too n everything else lol
