Body-lift hand-made.
Old Nov 7, 2008 | 02:51 AM
Tetenok's Avatar
Tetenok is an unknown quantity at this point
Default Body-lift hand-made.
Hello, I would like to lift my Chevrolet Blazer 4dr 4x4 about 60 mm.
What sizes of the kaprolon prorate of bolt and nut needed?
How many it is required?
Old Nov 7, 2008 | 11:28 AM
WolfPack's Avatar
Default RE: Body-lift hand-made.
Well the nut should be welded to the body, so you only need longer bolts. The 2 inch body lift kits over here come with (12) 12mm x 140mm carriage bolts, (8) 7/16' USS washers, and (6) 3/8' USS washers.
If you want a 60mm lift (about 2.25 inches), you would just need a longer bolt. the extra .25 inches of lift would need an extra 6 or 7 mm longer on the bolt. Hope this helps!
Edit: Are you sure Kaprolon (which I assume is the commercial name for Kapron?) is strong enough for the body lift? The kits over here use compressed nylon, which is what kapron looks to be...but I'm just not sure what the strength rating would be..
Old Nov 7, 2008 | 10:58 PM
91blazermaniac's Avatar
91blazermaniac is an unknown quantity at this point
the exact blot size you would need would be (8) of the M12 x 1.75 x 150mm long this will be perfect for the 60mm lift and some washers in there too.
Old Nov 8, 2008 | 05:17 PM
_97Jimmy_'s Avatar
_97Jimmy_ is an unknown quantity at this point
i just use hockey pucks
Old Nov 9, 2008 | 03:12 AM
WolfPack's Avatar
Hockey pucks will deteriorate eventually..and you still need new bolts
If he can get kaprolon at a low price, it would definitely be the best choice for durability
Old Nov 9, 2008 | 08:10 AM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
You could always just buy the blocks from synergyoffroad ( http://www.shop.synergyoffroad.com/p...&categoryId=10 ) and then get all the hardware from a local hardware store. Might be cheaper that way. However, you don't really wanna go cheap on anything when it comes to a body lift.
Old Nov 9, 2008 | 02:32 PM
_97Jimmy_'s Avatar
synergyoffroad is a good place for them, i was kidding about the hockey pucks but ive seen them used for body lifts before, very interesting. we also mount transformers with them.
Old Nov 13, 2008 | 08:51 AM
Tetenok's Avatar
Thanks to all for the answers on my questions!
And I have some questions.
I need only (8) M12 x 150mm??? And nothing more?
What is USS washers?
And I found the bolt M12X150mm.
Old Nov 18, 2008 | 06:32 PM
samuknow's Avatar
samuknow is an unknown quantity at this point
Show us some pics when you get it done or along the way for that fact.
Old Dec 9, 2008 | 05:21 AM
Tetenok's Avatar
Kaprolon prorateand bolt.
SmoyMoose
Mar 30, 2010 07:41 AM
kiwi
Nov 6, 2009 10:45 PM
Boopappa
Sep 3, 2009 10:08 AM
94blueknight
The Chop Shop
Mar 18, 2008 11:58 PM
XBlazer01
Sep 12, 2006 12:29 PM
