Changing tires
Old May 28, 2017 | 02:28 PM
Jacobsblazer's Avatar
Jacobsblazer is on a distinguished road
Default Changing tires
I have a 98 4door and want to run 31 10.5s on stock rim. Does anyone know if I can run them on stock hight?
Old May 28, 2017 | 05:52 PM
Old May 28, 2017 | 06:19 PM
newguy's Avatar
I had a 98 4door, took 2 inch lift and 2 inch body lift to run 31s
Old May 29, 2017 | 12:14 AM
for what it's worth, I ran 31's on my 04 with a shackle and torsion bar adjustment lift on some aftermarket 2wd offset wheels and they STILL rubbed pretty bad even after hammering on the fender and trimming the front valance...
Old May 29, 2017 | 07:48 AM
El_Beautor's Avatar
Everyone's experience varies, but most people need a minimum of 2" of lift to run 31's on a 4 door Blazer. Your best bet in my opinion is to do a 2" body-lift to start, and see where you sit after that. I suggest that simply because it maintains the stock suspension geometry, while getting more room to clear taller tires. After that if you still need more room there are a few different suspension lift options for you to explore. Tons of info on the forum. Good luck!
Striker911
Mar 6, 2014 11:56 AM
Steve Stracquatanio
Apr 24, 2012 08:35 PM
98Ltblazer
Aug 19, 2010 07:06 PM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
blazerbob
Tires and Wheels
Mar 19, 2007 08:38 PM
