Do you think I can run 38's
http://i496.photobucket.com/albums/r.../blazer001.jpg
I have 36's with no rubing Do yall think I can get away with 38's? |
RE: Do you think I can run 38's
I think you will be damn close. How close to the frame/body do those 36"ers come when you are at full lock with flex?
maybe about a inch from the flares, depends how big of a rock I get on.
RE: Do you think I can run 38s
They you would probably hit with 38s. Have you done any trimming?
No everything is stock, what could I trim? my flares?
If you have to, you could trim/bash the wheel wells in the back to gain additional clearance. If you are within an inch at full flex, you will be close.
Thanks, I just bought these tires so when they go I might get some 37's
You'll have front axle problems with anything bigger than what youve got. If you want to go with 38s, go SFA and swap the rear axle.
I wouldnt be suprised if you snap a half shafts if you do any heavy offroading with your current setup. |
ORIGINAL: WolfPack You'll have front axle problems with anything bigger than what youve got. If you want to go with 38s, go SFA and swap the rear axle. I wouldnt be suprised if you snap a half shafts if you do any heavy offroading with your current setup. |
Give it time:D You'll SFA eventually;)
