hi
Old Nov 18, 2005 | 06:30 PM
kuwaity's Avatar
kuwaity is an unknown quantity at this point
Default hi
any one can help me please I have 1990 Chevrolet Blazer and I want to install 33/12.50r15 tire . do I have to changing the transmission ? the transmission is 750 and the ENGINE is 350ci V8
Old Nov 18, 2005 | 09:29 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default RE: hi
You've already asked this question here. Try not to post the same thing more than once. It's against the rules.
Old Nov 19, 2005 | 04:18 AM
kuwaity's Avatar
Default RE: hi
I'm sorry
but can you help me about the problem
Old Nov 19, 2005 | 03:14 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: hi
im guessing you have a full-size? you'll be fine w/ 33's. on my old 3/4 ton i ran 35's with the stock 700r4. i did change the ring and pinions to 4.10:1 to get a little lower gearing. i had no problems with the tranny, though, and i beat the crap out of that truck.
Old Nov 21, 2005 | 03:20 AM
kuwaity's Avatar
Default RE: hi
thanks for your reply.
but the problem is that I have change the transmission 2 time . I don’t no what to do
Old Nov 22, 2005 | 05:35 PM
Hanr3's Avatar
Default RE: hi
Heat is the number one killer of trannies. Upgrading ring and pinion gears will keep the tranny and engine in the proper power band and reduce the amount of heat generated, plus pick up some lost performance. However to make the tranny survive, I would recommend an auxiliary tranny cooler. The tranny will generate tons of heat while 4wheeling. Proper ring and pinions will only reduce that a little, the auxilary tranny cooler will help the most.
