light roof rack
what roof rack is best for a blazer with a sunroof that gets the best view of the area i dont want to get the carrier just the lights and i wanna have it hold 4 square lights
Why dont you just get a light bar instead then? Theyre cheaper.
Originally Posted by Jfutch101
(Post 223493)
Do you mean, "What roof rack works best for a Blazer with a sunroof?" "I want one that doesn't restrict my sun roof view." "Now that you have loooked for a roof rack for me, I don't want it. Instead, I want some lights." "I want a roof rack with 4 square lights." Um.... If I interpreted that correctly, then why bother with a roof rack at all? Go with mech cb's light bar suggestion, or go to Autozone or Walmart and drop $40 on 4 cheap Platinum Burners Series square lights and mount them to your cross bar on the cargo rack. Seriously, wha...!? cheap ass cargo basket cheap ass lights |
Or you could go the extreme route & do what I did - If we're talking lights. LOL
Check out my album. I used what is locally known as "KIWI INGENUITY" |
yea im looking for a bar to hold lights not a rack how do you run the wires to the interior
yes i want to do mine exactly like you kiwi how did you do it
Before I started, I wanted the lights as far forward on the roof as possible without drilling into the roof. ALSO, I wanted to retain the use of the roof rack.
The light bar was from a pair of roof racks off a Jeep Cherokee. I shortened it & mounted it to an aluminium plate I cut to fit in the top of the roof rack's feet. I fed the wires into the cross bar & out at the end & into a junction box on the roof. From there I fed the wires through the roof under the foot of the roof rack, followed down to the front pillar & under the dash. This is where you have your light switches. (my light switches are on the steering column like most Japanese vehicles). At first I had 2 toggle switches, one for the 2 outside lights & the other for the two inside ones, (because they're 100w lamps one switch would not cope). Each switch had a relay & I fed power directly from the battery with a 40amp fuse. Since then, I've refined the switches to what I have now. Check out the pics on my photobucket album. |
I like they way you built that kiwi. I've been looking into light rack solutions, too.
is there a name so i can buy one and install like yours also what size are your lights
