make a 1988 s10 blazer a rock crawler
can i cut stuff off it and what tire size fits on it
I have moved this thread to the 'Off Roading' section where it may get more attention and deleted your second post. Please have patience and somebody will try to help you when they see the thread.
Have a look around. Tim (hanr3) wrote up a nice post quite some time ago about what tires fit. He had a 2nd gen with only a t-bar crank that he fit 31" tires on, if I remember correctly. But as I recall, he had to do some trimming/beating.
Depends if it is your daily driver? Just looking to turn a beater into a dirt cheap rock crawler?
Cut the fenders up, trim your front bumper, take the sway bars off, 2" Shackles, 3" body lift, 1.5" Tbar crank and run some 33" tires. Build some cheap aluminum diamond plate skid plates and have some fun! |
can you cut the top off a s10 1988 1 gen blazer
You can cut the top off of just about any full frame vehicle. You might want to add some more body supports in and/or make up a rocker box to support the door openings, but it is definitely do-able. All depends on your experience level.
how do i do a t-bar lift
You turn the Tbar bolts, you should try searching for a bit nobody wants to take the time to tell you how to do everything if you dont want to take the 5 minutes it would take to search Tbar crank, and what size tire will fit. If you can't figure out how to lift using Tbars I don't forsee you building a rock crawler.
well i look around and could not find how to lift
https://blazerforum.com/forum/showth...hlight=torsion
Just make sure you spend some time browsing the forum for how-to's and such before you start asking questions. Post some pictures of your truck and give some details on it helps as well. We need to know if it's your only vehicle that you drive everyday or if it's just a beater truck before we can tell you what you can cut off. |
its a beater truck
hey ive heard of people making diamond plate skidplates and stuff and i thought it would be cool if i had a diamond plate cargo liner. does anyone know who makes one or how to make one myself?
search t-bar, torsion, lift, tires, suspension
choose the threads with lots o replies generally, or take more time and look at them all. There is a @#$% load of info in here |
Originally Posted by zsmith93
(Post 224109)
