Need advice
Old Nov 27, 2007 | 10:34 PM
mdehoogh's Avatar
Default RE: Need advice
i dunno if this is right or not
6lbs boost on top of ~14psi normal air pressure would be 20psi going into the engine.
20/14 = 1.429
190 x 1.249 = 271.51
271.51 - 190 = approx 81 hp?
i have absolutely no idea if that is correct or not. there was a kid in my intro to engineering class who was telling me thats how he found out how much hp his s/c cobalt was making. i would think a supercharger would add more than that. but i could be completely wrong. i couldnt find any numbers or dyno sheets on their website
Old Nov 27, 2007 | 10:37 PM
Tippman7641's Avatar
Tippman7641 is an unknown quantity at this point
that not awhole lot for 2.5k considering i think a cold air intake for only 190 will rais u about 7-10hp i for get the exact numbers
Old Nov 27, 2007 | 10:41 PM
mdehoogh's Avatar
that seems about right. my K&N CAI said its like 7.1 hp. but thats also at like 4800rpm which is hardly reachable driving in the city
Old Nov 27, 2007 | 10:46 PM
my town is mostly back roads and im a heavy throttle user so wat ever i can get is good
Old Nov 27, 2007 | 10:48 PM
AHAAAA this is the exact look im going for http://i159.photobucket.com/albums/t...B/RC2sig-2.jpg
Old Nov 27, 2007 | 10:53 PM
mdehoogh's Avatar
ORIGINAL: Tippman7641
thats the same guy i was talking about who squeezed on 33's with the body/susp lift
Old Nov 27, 2007 | 10:55 PM
damn lol, i dont have near enought for all that i just like the look of it
Old Nov 28, 2007 | 03:22 PM
jphayes921's Avatar
jphayes921 is an unknown quantity at this point
just do a sfa conversion, if your looking to go that big.
Old Nov 28, 2007 | 05:07 PM
Hanr3's Avatar
I wouldn't go over 33" tires. The drivetrian wont survive with 35" tires, unless you baby it.
To get 33" under it you have several options.
Fender trimming.
Body lift and fender trimming.
6" suspension lift.
To get bigger tires, go with a solid axle swap.
To keep up with your friends, install the 33" meaty tires (however you like) and install a rear locker and front limited slip. Then remove your front sway bar, or at least disconnect it, and install some 2" shackles in teh rear and crank the front t-bars 1". With this set up you will have good ground clearance, they will have maybe 1" more if they are running 35" tires. They will have better articulation, however a good driver can get around that most of the time. Most of the limitation is the driver, not the vehicle.
Old Nov 28, 2007 | 07:19 PM
kankoon52's Avatar
kankoon52 is an unknown quantity at this point
i agree i wouldnt go over 33" tires unless you do a solid axle swap and a engine swap to a v8.
