question?
is there anything you can get put on the bottom of your car to prevent water from splasing up into the engine?
RE: question?
From the picture of you getting stuck theres not much to help lol
Anyhow maybe you could fab some kind of extended section to put on your "skid plate". I would just seal up all your connections real good and wiring etc. |
RE: question?
get a snorkel
RE: question?
Where are you worried about water getting? The underside is pretty protected from non-boat oriented maneuvers :D
Edit: Just saw your pic. Nice [8D]. But yea that ones tough. Even if you sealed off the bottom side, theres holes all throughout the body for venting/flexing/weight saving. If youre going to be doing that alot, you might want to extend your differential vent tubes..water + gear oil does not work too well for the axles. |
RE: question?
ok thanks guys.....i guess ill just take it easy next time....my engine actually didnt stall in the picture when i was stuck!! it was later that day. i had to leave my car there overnight to let the engine dr out.
RE: question?
yeah be very careful.
Hydrostatic lock will blow a motor faster than over-rev with no oil. and its almost always more expensive. at least with an over-reved engine the pistons usually stay IN the block... |
RE: question?
hahaha well said:D
If you end up in water, first step before restarting is to make sure your air filter is dry! |
RE: question?
yeah....she didnt sound so hot for a while thats why i had to leave it over night.
