question?
Old Dec 14, 2008 | 10:25 PM
Black 1998 Blazer's Avatar
Black 1998 Blazer is an unknown quantity at this point
Default question?
is there anything you can get put on the bottom of your car to prevent water from splasing up into the engine?
Old Dec 14, 2008 | 10:52 PM
Jerry60k's Avatar
Jerry60k is an unknown quantity at this point
Default RE: question?
From the picture of you getting stuck theres not much to help lol
Anyhow maybe you could fab some kind of extended section to put on your "skid plate".
I would just seal up all your connections real good and wiring etc.
Old Dec 14, 2008 | 10:57 PM
NVANZEE's Avatar
get a snorkel
Old Dec 15, 2008 | 03:32 AM
WolfPack's Avatar
Where are you worried about water getting? The underside is pretty protected from non-boat oriented maneuvers
Edit: Just saw your pic. Nice [8D]. But yea that ones tough. Even if you sealed off the bottom side, theres holes all throughout the body for venting/flexing/weight saving. If youre going to be doing that alot, you might want to extend your differential vent tubes..water + gear oil does not work too well for the axles.
Old Dec 15, 2008 | 06:32 AM
ok thanks guys.....i guess ill just take it easy next time....my engine actually didnt stall in the picture when i was stuck!! it was later that day. i had to leave my car there overnight to let the engine dr out.
Old Dec 15, 2008 | 11:54 AM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
yeah be very careful.
Hydrostatic lock will blow a motor faster than over-rev with no oil.
and its almost always more expensive.
at least with an over-reved engine the pistons usually stay IN the block...
Old Dec 15, 2008 | 02:46 PM
WolfPack's Avatar
hahaha well said
If you end up in water, first step before restarting is to make sure your air filter is dry!
Old Dec 15, 2008 | 06:48 PM
yeah....she didnt sound so hot for a while thats why i had to leave it over night.
2001Blue
Lifting Tech
Jan 1, 2011 07:15 PM
98Ltblazer
Apr 11, 2010 11:34 PM
Numba1Sean
May 6, 2009 11:48 PM
redfan13
Mar 11, 2008 09:37 PM
Chadoo951
May 6, 2007 07:01 PM
