Whats the biggest tire to put on our stock rims??
I got a 88 2.8 Blazer with only 58,000 original miles. Its been garaged its whole life and is super clean. Anyway I live up in Montana and need to get it ready for the snow. I wondered what would be the best size tires to upgrade to?? Not sure what size?? pros and cons??
Thanks
Jeff
Thanks
Jeff
Biggest size on stock 4x4 rims in a 4x4 is 30".
To answer your subject question. Any tire diameter size you want, as long as you keep the wideth to 11.5" or less. Getting them to fit the wheel wells is a different subject.
Being a '88, no doubt it came stock with 215/225. 235 is a good tire size to run. The next larger size is the 30". The key thing is the tread of the tire. I prefer to run the BFG All-Terrains. They have excelent handling in the snow, and rain, plus they do decent in the mud, and they do excellent in the sand. No tire does any good on ice, unless you can run spiked snow tires, or chains.
Going to larger tires does have its draw backs, speedo will be off, so will the odometer.
The truck will feel like it lost power.
ORIGINAL: 88Blazin
Thanks
Jeff
Thanks
Jeff
30x9.5x15 is the biggest and widest that will fit stock height/stock rim 4x4 S-10's. try tirerack.com can get A/T's for under 100 bucks on several different brands. Im just assuming that A/T's will be what you want for a montana winter.
